When I was using VS2005 with Infragistics 2009 V2, I never experienced and problem at all.. I have upgrading to Windows 7 (64bit), after I have installed VS2005 and Infragistics 2009 v2 with no problem, but when I run the utility to install toolbox on VS, it resulted the following error... Please help me, I need your help badly... I have only few more days to complete my project to meet the deadline.
06:05:23: Processing command line parameters.06:05:24: Begin processing NetAdvantage version 9.206:05:24: Beginning to process VS v8.006:05:24: Getting Type for ProgID: VisualStudio.DTE.8.006:05:54: Retrieving the COM class factory for component with CLSID {BA018599-1DB3-44F9-83B4-461454C84BF8} failed due to the following error: 80080005.06:05:55: at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandle& ctor, Boolean& bNeedSecurityCheck) at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean fillCache) at System.RuntimeType.CreateInstanceImpl(Boolean publicOnly, Boolean skipVisibilityChecks, Boolean fillCache) at System.Activator.CreateInstance(Type type, Boolean nonPublic) at ToolboxUtilitySupport.ToolboxManager.CreateDTEObject(String visualStudioProgId) at ToolboxUtilitySupport.ToolboxManager.CreateTabs(String visualStudioProgId, TemplateToolbox toolboxTemplate, IgProduct productToInstall) at ToolboxUtilityCommandLine.Program.Main(String[] args)
