I have a table that shows the Person's ID, Name, Exam date and marks scored by him. The marks can be positive or negative based on the response provided. The data in the grid is like this:
ID | Date | Name | Marks |
1 3/20/14 Alex 10
1 3/22/14 Alex -10
2 4/25/14 James 5
2 4/25/14 James 10
3 4/25/14 Peter 12
3 4/25/14 Peter -12
If I apply the grouping By Name, Data would look like this:
1 Multiple Alex 0
2 4/25/14 James 15
3 4/25/14 Peter 0
Which grid on which platform are you using?
Hi Alan,
I am using UltraWinGrid on Windows platform.
Filtering is not supported features for GroupByRows, so what I could suggest you is to iterate trough GroupByRows in order to hide/unhide needed ones. Something similar to this that I’ve done in my sample, select the group row which you want to leave from the combo next to the grid.
I hope that this will helps you.
Hello, I am just checking about the progress of this issue. Let me know If you need my further assistance on this issue?Thank you for using Infragistics Components
Hi Hristo,
The solution provided by you will work for me. Thanks a lot for this. Nonetheless, I was seeking a way to achieve this using the inbuilt methods of UltraGrid. Is there any way to override the inbuilt methods of UltraGrid in such a way that this could be achieved without using an extra control?
