- NetAdvantage 2014.2 (also happened in 2013.1 before upgrading)
- .Net 4.5
- Visual Studio Professional 2013
I'm trying to design a grid in a standard WinForms application. I was able to set the look of it and add the initial set of columns just fine, but after a while it started misbehaving. The changes I made in the designer (most notably columns and summaries) were frequently not being saved to the form's designer file (MainForm.Designer.vb), which led to the designer reloading the old settings once I built the application.
This doesn't happen with the standard .Net controls added to the form, and the ultrawingrid is the only Infragistics control I use in this project.
For a little while it seemed like I could get around it by clearing the contents of licenses.licx, but that has also stopped working now. I can now successfully get it to update the designer file once every 10-20 attempts, which gets really annoying really quickly.
Any suggestions about why this is happening? This project is pretty much dead until I can finish designing this grid, so I hope there's a solution. Thanks!
Hi Matt,
This issue has been now resolved and it is scheduled to be released in our December service release. For more information on our release schedule, please visit this page:
http://www.infragistics.com/support/service-releases
Please let me know if you have any additional questions.
We're running into this problem too and it's been very annoying. Eventually the properties do "stick" in the designer file, but there appears to be no obvious trigger than makes it work or not work. Hopefully this will be fixed soon.
Matt
Hi Sindre,
The issue is currently being reviewed by our developers and I can’t give you a timeframe when it will be fixed. Please see my response in the private case for more details.
Hi Dimitar!
I was just wondering if you know how long I can expect it to be before anyone looks at this case? If it's going to take much longer I'm going to have to rebuild my application with another grid component. The customer can't wait for this project much longer, and I can't be stuck with a project that's basically impossible to maintain as it stands now.
Thanks!
Thank you for the provided sample.
I have investigated your issue and, I have asked our engineering staff to examine this further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system and I have opened a private case for you - CAS-159358-S2H0X3. You can view your currently active cases from this link:
https://www.infragistics.com/my-account/support-activity
