80
xamlBusyIndicator animation region size
Is there a way to specify/adjust the size of the animation region of the xamlBusyIndicator? The 'SpinnerBar' looks too big, I would like to reduce it by say 40%. Thank you.
  • 6365
    Verified Answer
    Hello Raymond,
    In order to set the size of the XamBusyIndicator's animation, you can create a Style for the respective animation element and set its Width and Height properties. In addition, this can be done in code-behind as well by accessing the AnimationPresenter property of the XamBusyIndicator.
    XAML:
    Code-behind:
    busyInd.AnimationPresenter.Height = 20;
    If you would like to increase/decrease the size based on percentages, you can use the ActualHeight and ActualWidth properties of the AnimationPresenter to make the necessary calculations.
    I have attached a sample application that demonstrates the approach from above.
    For more detailed information on configuring the layout of the XamBusyIndicator, you can take a look at the "xamBusyIndicator > Display > Busy Indicator Configuration" sample from our WPF Samples Browser. It will allow you to instantly generate a customly configured style.
    If you have any questions, please let me know.
    XamBusyIndicator_sample.zip
