how can I set the column width of the property grid? Currently I only can change the column width with the mouse at runtime.
Hello Markus,
In order to set the column width of the XamPropertyGrid, I would recommend that you set the NameColumnWidth property on the control. This will control the width of the column that displays the names of the properties in the XamPropertyGrid. The column width of the "editor" column will then be approximately the difference between the NameColumnWidth and the ActualWidth of the XamPropertyGrid itself.
Sincerely,AndrewAssociate Developer
