I upgrated from version 16.1 to 17.2 and recognized that the BorderBrush is not used from the assigined StackedFragmentSeries.Brush color any more.
Is this as designed or a malfunction?How can I set the Border color?
As you can see in the screenshot, in the new version the default color is used instead of the assigned Brush (DarkMetroTheme).
This is my code snippet:
<ig:StackedColumnSeries.Series> <ig:StackedFragmentSeries ValueMemberPath="QualityObjects"> <ig:StackedFragmentSeries.Brush> <SolidColorBrush Color="#64C480"/> </ig:StackedFragmentSeries.Brush>
When
Hello Markus,
There were a couple of visual changes to the XamDataChart between versions 16.1 and 17.2, and this was one of them. The blue border that you are seeing in the tooltip is coming from the Outline brush on your StackedFragmentSeries.
If you would like for the outer border to be the same as the color for your series, I would recommend setting this Outline property to a new SolidColorBrush, just as you have done for the Brush property for your StackedFragmentSeries object, like so:
<ig:StackedFragmentSeries.Outline> <SolidColorBrush Color="#64C480"/> </ig:StackedFragmentSeries.Outline>
Sincerely,AndrewAssociate Developer
