we have a XamDataGrid with several columns. Some columns are belong together (like a "Value" and a "Unit" column).Can we link two (or more) columns? I found some code to move the second after the user has moved the first column (via drag/drop). But we want that the user can drag/drop two columns together (at the same time). Is that even possible? Thank you!
Hello Simon,
I recommend you look into field grouping it would allow you to group the two columns and they reposition them by the group field:
https://www.infragistics.com/help/wpf/xamdatagrid-field-grouping
Sincerely,Mike P.Software DeveloperInfragistics, Inc.www.infragistics.com
