can I disabled the contextmenu on the contentpane via xaml? I wanted to edit the "PaneHeaderPresenter"-Style but there is the "positionMenu" already disabled.
Michael
Hello Michael,
I have been investigating into your requirement in this case, but I am a little unsure of exactly what you are looking to be able to do? Would it be possible for you to please confirm what you are trying to do with the context menu in this case? Are you looking to just disable certain items in it, remove certain items in it, or prevent it from opening entirely?
Hello Andrew,oh sorry, I want to prevent it from opening. So I want disable the context menu via xaml (Style).
Thank you for clarifying. I have been investigating further into your requirement in this case and it appears that you can do this by using the following styles:
<Style TargetType="{x:Type ig:PaneHeaderPresenter}"> <Setter Property="ContextMenu" Value="{x:Null}"/> </Style> <Style TargetType="{x:Type ig:PaneTabItem}"> <Setter Property="ContextMenu" Value="{x:Null}"/> </Style>
I hope this helps. Please let me know if you have any other questions or concerns on this matter.
