Hi Team,
I Need to use XamBusyIndicator using Binding ViewModel
But It's not working as expected.
When I giving the hard-coded value in IsBusy it's working. But when I use Binding its not working
In XAML
<ig:XamBusyIndicator IsBusy="{Binding IsBusy, Mode=TwoWay}" BusyContent="Please, wait ..."> <Grid>
< code for the grid>
</Grid> </ig:XamBusyIndicator>
in Viemodel
private bool isBusy; public bool IsBusy { get { return isBusy; } set { SetAndCallOnPropertyChanged(ref isBusy, value, () => IsBusy); } }
I will be making IsBusy= true and false inside my code logic. but it's not reflecting in XAML
if I use IsBusy="True" it's working but I need to get from Binding
Can anyone please guide and suggest me how to proceed further.
Nirmal
Hello Nirmal,
I am attaching a sample project that demonstrates binding the XamBusyIndicator to an IsBusy property in your ViewModel. I am guessing that something could potentially be wrong with your binding to IsBusy in this case, or potentially the work that you are doing could be blocking up the UI thread? In the sample project, I am populating and loading 10 million records into a XamDataGrid asynchronously through usage of a BackgroundWorker element on a Button click. The XamBusyIndicator works as expected in this sample project.
I hope this helps you. Please let me know if you have any other questions or concerns on this matter.
BusyIndicatorBinding.zip
