8130.WpfApp1.zip
I need to remove completely the hovering effect from XamDataGrid and change the foreground color.
I have set the BackgroundHover and the BorderHoverBrush properties of the DataRecordCellArea to Transparent and also the CellValuePresenter's ForegroundHoverStyle to my desired color.
But the problem is that if I hover over one cell the other cells of this row will change their foreground color and I dont want that.
How can I make the foreground color of all cells allways the same by hovering. I have attached my example program.
Thank you!
Pavel Svilenov
Hello ,
Thank you for posting. If you go to the following blog, there is a sample that demonstrates how to override the brushes for the various parts of the XamDataGrid.This includes the hover brush for cells and records also.
http://forums.infragistics.com/blogs/curtis_taylor/archive/2010/10/26/xamdatagrid-101-part-2.aspx
Since this post has an old sample I build it against the lasted supported version 18.2 and attached it here for your reference.
Let me know if you have any question.
Sincerely,Divya JainAssociate Software Developer
8662.XamDataGridsample.zip
