I use a XamDataGrid with AutoGenerateFields=True and record filtering.
For one field (datatype is Int32) I applied a Combobox style, but I don't want the filter cell to take this combobox style over, too.
I want the filter cell to keep it's 'FilterOperandUIType="UseFieldEditor"' look, so to be a numeric text editor.
To achieve this, I applied a FilterCellEditorStyle on the filter cell, based on XamNumericEditor.
But now, if you put in a filter value, the filter logic uses a string comparision, not a numeric comparision:
If the record values are 1, 2, 3 and you filter for '> 11', the result is '2, 3'.
So, is it possible to apply an EditorStyle only to data cells, not to the filter cell?
If not, how can I reach correct filtering behaviour?
Thanks for your help!
1057.WpfApp1.zip
Hello Florian,
I am able to reproduce the issue you described and logged into our internal system for further investigation with the dev id 269160.
I have created a private case CAS-206808-J5L1R7 to link the dev issue , you can access this case through your infragistics accounts 'Support Activity' page.
Let me know if you have any question.
