30
Get current Sortorder in XamGrid
I'm using a XamGrid to present Productinfos. The User is able to sort most of the columns as he likes. For Printing, I'm creating a FlowDocument and loop throw the Datasource of the XamGrid to copy the Data into a table. It all works fine and I'm able to Print or Preview all Data like it should be. The only problem I'm not able to resolve is to print the Data in the current used Sortorder. By looping throuh the DataSource, all Records are in the original Order, like it was at the time loading the Data into the XamGrid.
Is there a way to loop through all Records in the current Sortorder, like it is showen on the Screen by the time I start the printing?
Here are two codesnipets for better understanding:
XAML-Code for the XamDataGrid
<controls:ExtendedGrid Grid.Row="3" Margin="0,0,11,0" x:Name="DGArtikel" Theme="Office2013" GroupByAreaLocation="None" DataSource="{Binding Artikel}"
                                   FontSize="14" FontWeight="SemiBold" Focusable="False" SelectedItemsChanged="DGArtikel_OnSelectedItemsChanged" ScrollViewer.VerticalScrollBarVisibility="Auto"
                                   ScrollViewer.HorizontalScrollBarVisibility="Disabled">
            <controls:ExtendedGrid.FieldLayouts>
                <igDP:FieldLayout>
                    <igDP:TemplateField Column="0" AllowHiding="Never" Label="Vorschaubild" Name="ImageSource" Width="108" AllowSorting="False" AllowResize="False" >
                        <igDP:TemplateField.DisplayTemplate>
                            <DataTemplate>
                                <Image Source="{Binding RelativeSource={RelativeSource AncestorType=igDP:CellValuePresenter}, Path=Record.DataItem.(wm:CMSWarenkorbArtikel.ImageSource)}" Height="60" Width="80"/>
                            </DataTemplate>
                        </igDP:TemplateField.DisplayTemplate>
                    </igDP:TemplateField>
                    <igDP:TemplateField Column="1" AllowHiding="Never" Label="Artikel" Name="AusgabeArtikelText" Width="0.6*" >
                            <DataTemplate>
                                <TextBlock Text="{Binding RelativeSource={RelativeSource AncestorType=igDP:CellValuePresenter}, Path=Record.DataItem.(wm:CMSWarenkorbArtikel.AusgabeArtikelText)}" FontSize="14" FontWeight="SemiBold" HorizontalAlignment="Left" TextWrapping="Wrap" Margin="11,3,3,3" Foreground="Gray"/>
                            </DataTemplate>
                    <igDP:TemplateField Column="2" AllowHiding="Never" Label="Menge" Name="Anzahl" Width="0.06*" >
                        <igDP:Field.Settings>
                            <igDP:FieldSettings SortComparer="{StaticResource CustomNumericSort}" />
                        </igDP:Field.Settings>
                            <DataTemplate>
                                <TextBlock Text="{Binding RelativeSource={RelativeSource AncestorType=igDP:CellValuePresenter}, Path=Record.DataItem.(wm:CMSWarenkorbArtikel.Anzahl)}" FontSize="14" FontWeight="SemiBold" HorizontalAlignment="Right" Margin="11,3,3,3" Foreground="Gray"/>
                            </DataTemplate>
                    <igDP:TemplateField Column="3" AllowHiding="Never" Label="Nettopreis" Name="AusgabeNettoEinzelpreis" Width="0.15*" AllowSorting="False" >
                            <DataTemplate>
                                <TextBlock Text="{Binding RelativeSource={RelativeSource AncestorType=igDP:CellValuePresenter}, Path=Record.DataItem.(wm:CMSWarenkorbArtikel.AusgabeNettoEinzelpreis)}" FontSize="14" FontWeight="SemiBold" HorizontalAlignment="Right" TextWrapping="Wrap" Margin="11,3,3,3" Foreground="DarkGray"/>
                            </DataTemplate>
                    <igDP:TemplateField Column="4" AllowHiding="Never" Label="Summe" Name="GesamtpreisFormatiert" Width="0.15*">
                            <DataTemplate>
                                <TextBlock Text="{Binding RelativeSource={RelativeSource AncestorType=igDP:CellValuePresenter}, Path=Record.DataItem.(wm:CMSWarenkorbArtikel.GesamtpreisFormatiert)}" FontSize="14" FontWeight="SemiBold" HorizontalAlignment="Right" Margin="11,3,3,3" Foreground="DimGray"/>
                            </DataTemplate>
                </igDP:FieldLayout>
            </controls:ExtendedGrid.FieldLayouts>
        </controls:ExtendedGrid>
And this is the codesnippet for creating the table in a FlowDocument for Printing:
//Get Data from DataSource
DataTable dataTable = CreateDataTable<CMSWarenkorbArtikel>((IEnumerable<CMSWarenkorbArtikel>)this.DGArtikel.DataSource);
//Loop  throuh  all  Records  of DataSource
            foreach (DataRow dataTableRow in dataTable.Rows)
                TableRow tableRow = new TableRow();
                rowGroup.Rows.Add(tableRow);
                columnIndex = 0;
                foreach (DataColumn column in dataTable.Columns)
                    if (!fieldLayout.Fields.Any(x => x.Name == column.ColumnName))
                        continue;
                    Paragraph paragraph;
                    if (columnIndex == 0 && !string.IsNullOrEmpty(dataTableRow[column].ToString()))
                        System.Windows.Controls.Image image = new System.Windows.Controls.Image
                            Source = new BitmapImage(new Uri(dataTableRow[column].ToString())),
                            Width = 80,
                            Height = 60,
                            Margin = new Thickness(11, 8, 0, 0),
                            HorizontalAlignment = HorizontalAlignment.Center,
                            VerticalAlignment = VerticalAlignment.Center
                        paragraph = new Paragraph(new InlineUIContainer(image));
                    else
                        TextBlock textBlock = new TextBlock
                            Text = dataTableRow[column].ToString(),
                            Margin = new Thickness(5, 5, 5, 0)
                        paragraph = new Paragraph(new InlineUIContainer(textBlock))
                            TextAlignment = alignments[columnIndex]
                    TableCell cell = new TableCell(paragraph)
                        BorderBrush = new SolidColorBrush(Colors.Black),
                        BorderThickness = new Thickness(0.5, 0.5, 0.5, 0.5),
                        LineHeight = 30
                    tableRow.Cells.Add(cell);
                    columnIndex++;
