15
Adding FieldGroups to FieldItems list
Hello there, in our project we need to add FieldGroups into the FieldItems list of the FieldLayout. We need to do this from VM, since our view component is a generic one, meant to be reused.
Our problem is that adding the FieldGroups into the FieldItems links to unexpected behavior, like columns with bad arrangement, index out of range exception.
The code from below is from a bigger method, but this part is responsible for adding FieldGroups to FieldItems collection.
(It works, but not as good as we hoped.)
if (!string.IsNullOrEmpty(column.Group?.Id))
				if (!groups.TryGetValue(column.Group.Id, out var group))
					group = new FieldGroup
						Label = column.Group.Label,
						AllowHiding = column.Group.AllowUserHiding ? AllowFieldHiding.ViaFieldChooserOnly : AllowFieldHiding.Never,
						Visibility = column.Group.Visibility,
						LabelTextAlignment = column.Group.LabelAlignment
					groups[column.Group.Id] = group;
				group.Children.Add(field);
			else
				fieldLayout.FieldItems.Add(field);
		foreach (var group in groups.Values)
			if (!fieldLayout.FieldItems.Contains(group))
				fieldLayout.FieldItems.Add(group);
