40
Hiding columns in XamDataGrid is slow
We have a XamDataGrid with 100 columns and 4000 rows.   We made a column chooser control that allows the user to hide and show columns.  Hiding a column by setting the Field.Visibility = Collapsed takes several seconds on a fast machine and over 5 seconds on a slower one.  if we set the ColMaxWidth = 0 instead, then it's much faster, but that's not the same as making the column invisible.  We also tried removing the column from the FieldLayout, but that was just as slow.  Any suggestions on making column hiding and showing faster?  I have a simple test application that binds to a DataTable that shows the issue if you need it.
