Hi. In the winforms version of your combobox there is a nice feature to be able to bind a dataset to the combobox to show a grid in the drop down. Is this available in the XamComboEditor. If not any ideas how to set this up?
Basically, the XamComboEditor does not support this, but you could retemplate the ComboBoxDataItem's template and put a XamDataGrid inside, so that you can bind to a Collection,DataTable,etc.
<igEditors:XamComboEditor Name="xamComboEditor1">
<igEditors:XamComboEditor.Resources>
<DataTemplate DataType="{x:Type igEditors:ComboBoxDataItem}" >
<Grid>
<igDP:XamDataGrid x:Name="TextBlock" DataSource="{Binding Path=Value}" />
</Grid>
</DataTemplate>
</igEditors:XamComboEditor.Resources>
</igEditors:XamComboEditor>
Then create ComboBoxItemsProvider and add a ComboBoxDataItem, which Value property you can set to a DataTable,Collection,etc. Add the ComboBoxDataItem in the ComboBoxItemsProvider and set the ItemsProvider property of the XamComboEditor.
string[] values = new string[] { "value1", "value2", "value3" };ComboBoxDataItem cb = new ComboBoxDataItem();cb.Value = values;ComboBoxItemsProvider c = new ComboBoxItemsProvider();c.Items.Add(cb); xamComboEditor1.ItemsProvider = c;
Hope this helps.
Hey Alex. This is what I needed, thanks. Question. When I click the drop down it takes a second or two to actually drop down the grid. Does rendering the grid take that long? Do you have that problem? Thanks for your help on this..
Actually no.
On my machine it loads almost immeadiately. However, there could be some delay on low performance computers due to the increasing number of nested elements, as the Combo Items are actually XamDataGrids, and each one consists of many nested elements.
Hi Alex. Couple more questions.
1. When I bind to a long list the combobox doesn't put a vertical scrollbar in. How can I do this?
2. How do I setup a template so that when I click a row lets say with 3 columns I then show the one value of a specific cell in the closed combobox?
Sorry for all the questions but I'm stimped.. Thanks again for the help...
@ 1) I have the scrollbar, I am not sure why you do not see it. If you have a sample application, please attach it to your next post.
@ 2) Using this approach, this would not be possible, because we retemplated the ComboBoxDataItem, and this would be the selected item (a XamDataGrid).
I suggest using the Default styles for the XamComboEditor, that we ship in the DefaultStyles directory in the Infragistics folder on your computer and retemplating the XamComboEditor's template.
