370
Combobox SelectedItemChanged event fires on XamDataGrid horizontal scroll
Hi, I have a XamDataGrid control in which one of the columns is a ComboBox column. I have a SelectionChangedEvent defines on the ComboBox and it seems to work well in general. But the event seems be firing even if I scroll (down or up, doesn't matter) the Grid. Is this a known issue or am I doing something incorrectly. Please let me know.
Resources Section of XAML
<UserControl.Resources>
<igEditors:ComboBoxItemsProvider x:Key="exceptionlist">
            <igEditors:ComboBoxItemsProvider.Items >
                <igEditors:ComboBoxDataItem DisplayText="Not categorized" Value="0" />
                <igEditors:ComboBoxDataItem DisplayText="Zero Component - Trade level has valid PV" Value="100" />
                <igEditors:ComboBoxDataItem DisplayText="Zero Notional" Value="200" />
                <igEditors:ComboBoxDataItem DisplayText="Zero Fixed Rate" Value="300" />
                <igEditors:ComboBoxDataItem DisplayText="Out of the money trade" Value="400" />
                <igEditors:ComboBoxDataItem DisplayText="Securitised Swap - Notional not yet determined" Value="500" />
                <igEditors:ComboBoxDataItem DisplayText="Trade Dead in Front End - being investigated" Value="600" />
                <igEditors:ComboBoxDataItem DisplayText="Sheet overrides value to Zero" Value="700" />
                <igEditors:ComboBoxDataItem DisplayText="Forward starting float leg" Value="800" />
                <igEditors:ComboBoxDataItem DisplayText="ATM Swap - PV nets to zero" Value="900" />
                <igEditors:ComboBoxDataItem DisplayText="Product at Maturity" Value="1000" />
                <igEditors:ComboBoxDataItem DisplayText="Trade booking to be amended" Value="1100" />
                <igEditors:ComboBoxDataItem DisplayText="Market Data creation failure" Value="1200" />
                <igEditors:ComboBoxDataItem DisplayText="Written down trade" Value="1300" />
                <igEditors:ComboBoxDataItem DisplayText="Under investigation" Value="1400" />
            </igEditors:ComboBoxItemsProvider.Items>
        </igEditors:ComboBoxItemsProvider>
<Style x:Key="categoryliststyle" TargetType="{x:Type igEditors:XamComboEditor}" >
            <Setter Property="ItemsProvider" Value="{StaticResource exceptionlist}"/>
            <Setter Property="DropDownButtonDisplayMode" Value="Always"/>
            <!--Setter Property="SelectedItem" Value="{Binding SelectedCategory}"/-->
            <EventSetter Event="SelectedItemChanged" Handler="OnExceptionSelectionChanged"/>
        </Style>
</UserControl.Resources>
Below is the XAML for my XamDataGrid
<ig:XamDataGrid x:Name="xdgTradeExceptions" DataSource="{Binding TradeExceptionReport}" Height="650"
                                    Width="auto" ActiveDataItem="{Binding ActiveException, Mode=TwoWay}" GroupByAreaLocation="None"
                                    DataValueChanged="xdgTradeExceptions_DataValueChanged">
                        <ig:XamDataGrid.Resources>
                            <Style x:Key="reportlevelcolumns" TargetType="{x:Type ig:LabelPresenter}">
                                <Setter Property="Background" Value="LightBlue" />
                            </Style>
                            <Style x:Key="othercolumns" TargetType="{x:Type ig:LabelPresenter}">
                                <Setter Property="Background" Value="LightGreen"/>
                            </Style>
                            <Style TargetType="{x:Type ig:HeaderLabelArea}">
                                <!--Setter Property="FontWeight" Value="Bold"/>
                                <Setter Property="FontFamily" Value="Verdana"/>
                                <Setter Property="FontSize" Value="12"/>
                                <Setter Property="Height" Value="30"/-->
                            </Style>
                        </ig:XamDataGrid.Resources>
                        <ig:XamDataGrid.FieldLayoutSettings>
                            <ig:FieldLayoutSettings DataRecordPresenterStyle="{StaticResource DRPStyle}" SelectionTypeRecord="Extended" AutoGenerateFields="False"/>
                        </ig:XamDataGrid.FieldLayoutSettings>
                        <i:Interaction.Triggers>
                            <i:EventTrigger EventName="PreviewMouseRightButtonDown">
                                <actions:RecordActivationAction/>
                            </i:EventTrigger>
                        </i:Interaction.Triggers>
                        <ig:XamDataGrid.FieldSettings>
                            <ig:FieldSettings AllowEdit="False" Width="auto" Height="auto"  />
                        </ig:XamDataGrid.FieldSettings>
                        <ig:XamDataGrid.FieldLayouts>
                            <ig:FieldLayout Key="TradeExceptionModel">
                                <ig:FieldLayout.Fields>
                                    <ig:Field Name="Category" Label="Category Assigned" FixedLocation="FixedToNearEdge">
                                        <ig:Field.Settings>
                                            <ig:FieldSettings EditorType="{x:Type igEditors:XamComboEditor}" EditorStyle="{StaticResource categoryliststyle}"
                                                              LabelPresenterStyle="{StaticResource reportlevelcolumns}" AllowFixing="Near"
                                                              DataValueChangedNotificationsActive="True"
                                                              DataValueChangedHistoryLimit="1">
                                                <ig:FieldSettings.AllowEdit>
                                                    <Binding ElementName="lblIsEntitled" Path="DataContext.IsEntitledToEdit"/>
                                                </ig:FieldSettings.AllowEdit>
                                            </ig:FieldSettings>
                                        </ig:Field.Settings>
                                    </ig:Field>
</ig:FieldLayout.Fields>
                            </ig:FieldLayout>
                        </ig:XamDataGrid.FieldLayouts>
                    </ig:XamDataGrid>
Any help is appreciated.
Shravan
