Is there are way to customize the xamReportPreview control's menu (i.e., add or remove certain buttons like the magnifying glass)?
Hello ,
It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking through your post and I suggest you copy the default style for the XamReportViewer, which you can find in the DefaultStyles folder, which is installed by default here: C:\Program Files (x86)\Infragistics\NetAdvantage 2011.1\WPF\DefaultStyles \Reporting\ReportingGeneric.xaml file and you can add or remove controls in its ControlTemplate property.
Hello-
Is copying the default style for the XamReportPreview control and modifying it still the recommended way to customize the toolbar? I too am interested in hiding some (or all) of the toolbar buttons.
Thank you!
Hello Amanda,
I believe that for the moment this is the best approach for achieving this functionality. If I think of a better one I will update you both.
Hello. I wonder if a better approach is now available for this.
Hello Camilo,
Currently copying the default Style seems to be the best approach for achieving this functionality.
