I am using NA 2010.3.
I am using entity framework with xamDataGrid. When I query the database using QueryObject and if the query return 0 rows, the column header disappears. Is there a xaml setting for xamDataGrid such that the header remains eventhough the query result return 0 rows?
The header column is fine when there is data in the query result.
Thanks.
If the above suggestion helped you solve your issue please verify the thread as answered so other users may take better advantage of it.
