I have binded hierarchical data to XamDataGrid, and my first column is fixed by setting FixedField prop to True and it is working fine. The problem is when I scroll to right the expansionindicator (+) getting hide.
How do I keep this expansionindictor visible with my fixed column?
I couldn’t reproduce this behavior with our latest builds. Are you setting the Field.FixedLocation property to FixedFieldLocation.FixedToNearEdge? If this is the case what version and build number are you using?
Diyan Dimitrov
