Hi ,
We have requirement in our application to show column re-size handler only on the header row and not on each row of the Grid. I tired searching through layout settings and could not find something that fits this.
Can you please provide me with an workaround for this.
Hello Rama,
For resizing the columns of the xamDataGrid from the header and not from the row I'll take a look at any options. I'll send another update on this thread on Thursday.
Let me know if you have any questions with this matter. Thank you.
This is just an update on the thread that I am currently looking into the API of the xamDataGrid to allow only the column to be resized by the header and not from the row. To access the our API for the control can be found here: http://help.infragistics.com/NetAdvantage/WPF/2011.2/CLR4.0/?page=xamDataGrid.html.
I'll send another update for a progress on the thread for any options on this on Tuesday.
This is just an update on the thread that I am currently following up with engineering for any options on allowing the column to be resized only within the column header.
I will send another update for a progress on the thread on Friday.
Thanks for the update. Looking forward to a workaround the same.
-Rama
This is just an update on the thread that I have followed up with engineering and for the xamDataGrid does not contain any options within the control that would allow the column to be resized from the header only. At this point I can submit a feature request on your behalf and for the case on this is CAS-83100-5CVLRH.
