I am using the XamMultiColumnCombo and I am binding my datasource property to the combo's SelectedItem property. Is there another property I should bind to? I had to add Mode="TwoWay" to get that to work but it only works if I type in the combo box to select the item. If I select an item from the drop down with the mouse then tab out of the combo box the old value reappears in the combo box.
Glen
Hello Glen,
Thank you for your post. I have been looking into it and I suggest you follow this tutorial:
http://help.infragistics.com/NetAdvantage/WPF/2011.2/CLR4.0/?page=xamMultiCCE_Adding.html
where it is explained in details how to use the XamMultiColumnEditor with a DataSource. Please let me know if this helps you or you need further assistance on this matter.
The problem was the version of the assemblies I was using. I had to install the latest service release. (11.2.20112.2076). After that the combo updated the datasource properly.
Thanks again.
