I have created a custom data template for the LegendItemTemplate for my series and I have a legend style specified for the legend itself but I am not sure how to make the Series.Title in the data template use the Series.ActualBrush as its color. Here is my data template. All I did was remove the ItemDataBadgeTemplate.
<DataTemplate x:Key="LegendItemTemplate"> <StackPanel Orientation="Horizontal" Margin="1" Visibility="{Binding Series.Visibility}"> <ContentPresenter Content="{Binding Series.Title, TargetNullValue=Series Title}" /> </StackPanel> </DataTemplate>
If I add the binding to the legend style I don't have access to the Series object...it uses the control's datacontext which is my custom viewmodel.
Legend style:
<Style x:Key="LegendStyle" TargetType="ig:Legend"> <Setter Property="Opacity" Value="1" /> <Setter Property="Background" Value="Transparent" /> <Setter Property="Margin" Value="0" /> <Setter Property="BorderThickness" Value="0" /> <Setter Property="Foreground" Value="{Binding Series.ActualBrush}" /> </Style>
XamDock XAML:
<ig:XamDock x:Name="XamDataChartContainer" Margin="0" Grid.Row="0"> <ig:XamDock.Height> <MultiBinding Converter="{StaticResource WaveCollectionToHeightConverter}"> <Binding RelativeSource="{RelativeSource Mode=FindAncestor, AncestorType=UserControl}" Path="DataContext.SelectedWaveForms" /> <Binding ElementName="WaveFormCtrl" Path="Height" /> </MultiBinding> </ig:XamDock.Height> <ig:XamDataChart x:Name="xmDataChart" Margin="0" CrosshairVisibility="Collapsed" VerticalZoomable="False" VerticalZoombarVisibility="Collapsed" HorizontalZoomable="False" HorizontalZoombarVisibility="Collapsed" Visibility="{Binding Selected,Converter={StaticResource BooleanToVisibilityConverter}}" Background="Black" PlotAreaBorderBrush="Black" PlotAreaBackground="Black" Legend="{Binding ElementName=xmLegendOTC}" > <ig:XamDataChart.Axes> <ig:CategoryXAxis x:Name="xmXAxis" ItemsSource="{Binding WaveData}" Label="{}{TimeStamp}" Stroke="Transparent" MajorStroke="Transparent"> <ig:CategoryXAxis.LabelSettings> <ig:AxisLabelSettings Location="InsideBottom" Visibility="Collapsed" /> </ig:CategoryXAxis.LabelSettings> </ig:CategoryXAxis> <ig:NumericYAxis x:Name="xmYAxis" MajorStroke="Transparent" MinorStroke="Transparent"> <ig:NumericYAxis.LabelSettings> <ig:AxisLabelSettings Location="InsideLeft" Visibility="Collapsed" /> </ig:NumericYAxis.LabelSettings> </ig:NumericYAxis> </ig:XamDataChart.Axes> <ig:XamDataChart.Series> <ig:LineSeries LegendItemTemplate="{StaticResource LegendItemTemplate}" Thickness="2" ItemsSource="{Binding WaveData}" Brush="Green" MarkerType="None" UnknownValuePlotting="DontPlot" ValueMemberPath="Value" XAxis="{Binding ElementName=xmXAxis}" YAxis="{Binding ElementName=xmYAxis}" Title="{Binding WaveChannelName}" /> </ig:XamDataChart.Series> </ig:XamDataChart> <ig:Legend x:Name="xmLegendOTC" ig:XamDock.Edge="InsideTop" ig:XamDock.HorizontalDockAlignment="Left" ig:XamDock.VerticalDockAlignment="Top" Style="{StaticResource LegendStyle}"> </ig:Legend> <StackPanel Orientation="Vertical" ig:XamDock.Edge="InsideRight" ig:XamDock.VerticalDockAlignment="Top" Margin="0,0,0,0" > <TextBlock x:Name="Offset" Text="{Binding Offset, StringFormat=Offset: {0}}" Visibility="Visible" Margin="0,0,0,0" /> <TextBlock x:Name="LastDisplayed" Text="{Binding LastDisplayedTimeStamp, StringFormat=LastDisplayedTimestamp: {0:hh:mm:ss:fff}}" Visibility="Visible" HorizontalAlignment="Left" Margin="0,0,0,0"/> <TextBlock x:Name="BufferSize" Text="{Binding BufferSize, StringFormat=BufferSize: {0}}" Visibility="Visible" Margin="0,0,0,0" /> <TextBlock x:Name="CurrentDrawPosition" Text="{Binding CurrentPosition, StringFormat=CurrentDrawPosition: {0}}" Visibility="Visible" Margin="0,0,0,0" /> <TextBlock x:Name="LastBufferTime" Text="{Binding DebugLastTimeStamp, StringFormat=LastBufferTime: {0:hh:mm:ss:fff}}" Visibility="Visible" Margin="0,0,0,0" /> </StackPanel> </ig:XamDock>
</ig:XamDock>
Well, not sure if this is the best way but I just changed the data template to use a TextBlock rather then ContentPresenter so that I could set the Foreground directly. This works just fine:
<DataTemplate x:Key="LegendItemTemplate"> <StackPanel Orientation="Horizontal" Margin="1" Visibility="{Binding Series.Visibility}"> <!--<ContentPresenter Content="{Binding Series.Title, TargetNullValue=Series Title}" />--> <TextBlock Text="{Binding Series.Title, TargetNullValue=Series Title}" Foreground="{Binding Series.ActualBrush}" /> </StackPanel> </DataTemplate>
Mike,
That's seems an acceptable solution. Silverlight has some oddities in this area as to which controls it will propagate foreground to or not.
-Graham
