40
XamDatagrid WPF Nested Summary Display
Good morning,
  I currently have many XamDataGrids and am having a problem with the display of the nested rows. I would like to remove the extra gray bars you can see in the example. The Summary row and the header are overflowing and I am not positive why.. I will attach the XAML, a screen shot, and whatever else you need. Please let me know what more information I can provide. I am currently working with the 13.2 version of your WPF controls.
Thank you,
  Scott Donald
<UserControl.Resources>
<Style TargetType="{x:Type igdp:DataRecordCellArea}">
<Setter Property="Background" Value="{StaticResource WrapLightGrayBrush}" />
<Setter Property="BorderBrush" Value="{StaticResource WrapMediumGrayBrush}" />
<Setter Property="BackgroundActive" Value="{StaticResource WrapLightBlueBrush}" />
<Setter Property="BorderActiveBrush" Value="{StaticResource WrapMediumBlueBrush}" />
<Setter Property="BackgroundHover" Value="{StaticResource WrapMediumBlueBrush}" />
<Setter Property="BorderHoverBrush" Value="{StaticResource WrapDarkBlueBrush}" />
</Style>
<Style TargetType="{x:Type igdp:HeaderPrefixArea}" x:Key="HeaderPrefixStyle">
<Setter Property="Template">
<Setter.Value>
<ControlTemplate>
     <wrapCommonControls:ToolbarMenu HorizontalAlignment="Center" Margin="0,0,14,0">
         <wrapCommonControls:ToolbarMenu.MenuContent>
             <StackPanel Orientation="Vertical" />
          </wrapCommonControls:ToolbarMenu.MenuContent>
     </wrapCommonControls:ToolbarMenu>
</Style>
</UserControl.Resources>
<igdp:XamDataGrid x:Name="trackerProductList" Grid.Row="0" HorizontalAlignment="Center" VerticalAlignment="Top" Visibility="{Binding Path=LoadOptionsVM.HasUserDoneLoad, Converter={StaticResource BooleanToVisibilityConverter}}" DataSource="{Binding Payments, ValidatesOnDataErrors=True, Mode=TwoWay, BindsDirectlyToSource=True}" ActiveDataItem="{Binding SelectedPayment, Mode=TwoWay}" FontSize="12" FontFamily="Segoe UI" ScrollingMode="Deferred" BorderBrush="{StaticResource WrapDarkBlueBrush}" GroupByAreaLocation="None">
<igdp:XamDataGrid.FieldSettings>
<igdp:FieldSettings SummaryDisplayArea="BottomFixed" LabelTextWrapping="NoWrap" Width="Auto" AutoSizeOptions="DataCells, Label" AllowEdit="False" AllowFixing="Near" AllowRecordFiltering="True" FilterLabelIconDropDownType="MultiSelectExcelStyle" Height="30" LabelMaxHeight="30" AllowSummaries="True" />
</igdp:XamDataGrid.FieldSettings>
<igdp:XamDataGrid.FieldLayouts>
<igdp:FieldLayout>
<igdp:FieldLayout.SortedFields>
<igdp:FieldSortDescription Direction="Ascending" FieldName="DealType" />
<igdp:FieldSortDescription Direction="Ascending" FieldName="ProductName" />
<igdp:FieldSortDescription Direction="Ascending" FieldName="TrackerNumber" />
</igdp:FieldLayout.SortedFields>
<igdp:FieldLayout.SummaryDefinitions>
<igdp:SummaryDefinition Key="AccruedUnits" SourceFieldName="AccruedUnits" Calculator="Sum" StringFormat="{} Total: {0:n0}" />
</igdp:FieldLayout.SummaryDefinitions>
<igdp:FieldLayout.Settings>
<igdp:FieldLayoutSettings HeaderPrefixAreaStyle="{StaticResource HeaderPrefixStyle}" FixedFieldUIType="Button" ExpansionIndicatorDisplayMode="CheckOnDisplay" RecordSelectorExtent="65" HeaderPrefixAreaDisplayMode="FieldChooserButton" AllowFieldMoving="WithinLogicalRow" AutoGenerateFields="False" FilterUIType="LabelIcons" HeaderPlacement="OnTopOnly" SupportDataErrorInfo="RecordsAndCells" AllowClipboardOperations="All" CopyFieldLabelsToClipboard="False" />
</igdp:FieldLayout.Settings>
<igdp:FieldLayout.Fields />
</igdp:FieldLayout>
<igdp:FieldLayout x:Name="NestedRow" >
<igdp:FieldLayout.FieldSettings>
<igdp:FieldSettings DataItemUpdateTrigger="OnCellValueChange" AllowRecordFiltering="True" AllowFixing="Near" AllowEdit="False" SummaryDisplayArea="BottomFixed" />
</igdp:FieldLayout.FieldSettings>
<igdp:FieldLayoutSettings FixedFieldUIType="Button" ExpansionIndicatorDisplayMode="Never" RecordSelectorExtent="65" HeaderPrefixAreaDisplayMode="None" AllowFieldMoving="WithinLogicalRow" AutoGenerateFields="False" FilterUIType="LabelIcons" HeaderPlacement="OnTopOnly" SupportDataErrorInfo="RecordsAndCells" AllowClipboardOperations="All" CopyFieldLabelsToClipboard="False" />
<igdp:FieldSortDescription Direction="Ascending" FieldName="GeoName" />
<igdp:SummaryDefinition Key="TotalPayOutUnits" SourceFieldName="TotalPayOutUnits" Calculator="Sum" StringFormat="{} Total: {0:n0}" />
<igdp:SummaryDefinition Key="TotalPayOutDollars" SourceFieldName="TotalPayOutDollars" Calculator="Sum" StringFormat="{} Total: {0:C}" />
