I have three radial gauges showing three values. Each of these values is calculated "simultaneously" (bound to values of an array returned by a method).
Each gauge has the same TransitionDuration="500":
The behaviour is, however, that sometimes the needles are moving smoothly, as expected, and sometimes they make a small jump from the initial position, then stay there for the rest of the TransisitonDuration without any movement and then they "jump" to the end position (no smooth moving). Additionally, I have an impression that when this "jumping" takes place then the event handling in general is blocked for a moment...
What could be the reason of?
Regards
Piotr
Btw. The values, the gauges are bound are not calculated frequently (at user click somewhere). I had no problems of this nature using a "free" gauge, so I don't have any doubt that the values bound to are calculated once.
Investigating the problem I have added a xamLinearGauge to the application to display the sane values as the radial gauges do, which, when used without the xamRadialGauge, works as expected (smoothly).
Adding the xamRadialGauge leads to the effect described previously. This means to me that there is really no problem with the values set, but some with xamRadialGauge.
Thank you for your post.
I have been looking into it. I created short sample application based on your scenario and I could not managed to reproduce the behavior that you have described. If you are not able to reproduce the issue with the attached sample application, would you please modify it with the functionality, that you are using, so it reproduces the issue. This way I would be able to further investigate this for you and provide you with more detailed information on this matter.
Hello Zhivko,
Thank you for your assistance.
Meanwhile, I have placed a support case CAS-157040-N2W3N6 which is under investigation. Please contact Andrew, who is processing the case and eventually join your activities and experience. I'm optimistic that the problem will be solved.
Cheers
Hello Piotr,
Thank you for your feedback.
