Summary values are not showing up in footer, please help. sample code listed below.
wbgdata1.Behaviors.CreateBehavior<SummaryRow>();
this.wbgdata1.Columns[1].Footer.Text = "Totals:";
//Summary Footer for Cartons
SummaryRowSetting BNCartonsSummary = new SummaryRowSetting(wbgdata1, "DDCARG");
BNCartonsSummary.ShowSummaryButton = false;
BNCartonsSummary.SummarySettings.Add(SummaryType.Sum);
this.wbgdata1.Behaviors.SummaryRow.ColumnSettings.Add(BNCartonsSummary);
wbgdata1.ShowFooter = true;
Thanks.
Tried adding the following code and getting the error "cannot convert from infragistics.web.ui.gridcontrols.summaryrowsetting to string". Column is defined as integer, not sure why I am getting this error.
this.wbgdata1.Behaviors.SummaryRow.ColumnSummaries.Add(BNCartonsSummary);
I am getting the same error for the code below also.
ColumnSummaryInfo BNCartonsSummary1 = new ColumnSummaryInfo();
BNCartonsSummary1.ColumnKey = "DDCARG";
BNCartonsSummary1.Summaries.Add(SummaryType.Sum);
wbgdata1.Behaviors.SummaryRow.ColumnSummaries.Add(BNCartonsSummary1);
Please help.
More details as listed below.
I am getting the error "cannot convert from infragistics.web.ui.gridcontrols.summaryrowsetting to string". Column is defined as integer, not sure why I am getting this error.
Columns are added manually as listed below:tblShipment = new DataTable("Shipment");tblShipment.Columns.Add(new DataColumn("Cartons", typeof(int)));
tc = wbgdata1.Columns["DDCARG"] as TemplateDataField;
if (tc == null)
{tc = new TemplateDataField();
tc.Key = "DDCARG";
tc.ItemTemplate = new PlaceHolderTemplate();
this.wbgdata1.Columns.Add(tc);
Based upon the error message provided it appears that you are trying to set a string to SummaryRowSetting. I may be able to investigate this further if you provide runnable isolated sample replicating the issue.
Looking forward for your sample.
Denis,
Could you please put together a sample with Webdatagrid where the columns are created manually with the summary data showing in footer values?.
Thanks for your help.
Srini
Please see the sample code that produces the error.
using System;
using System.Data;
using System.Collections.Generic;
using System.Linq;
using System.Web;
using System.Web.UI;
using System.Web.UI.WebControls;
using Infragistics.Web.UI.GridControls;
namespace WebApplication4
public partial class WebForm1 : System.Web.UI.Page
protected void Page_Load(object sender, EventArgs e)
GetData();
FooterValues();
public void FooterValues()
this.WebDataGrid1.Columns[0].Footer.Text = "Totals:";
WebDataGrid1.Behaviors.CreateBehavior<SummaryRow>();
ColumnSummaryInfo CartonsSummary = new ColumnSummaryInfo();
CartonsSummary.ColumnKey = "NumOfCartons";
CartonsSummary.Summaries.Add(SummaryType.Sum);
WebDataGrid1.Behaviors.SummaryRow.ColumnSummaries.Add(CartonsSummary);
SummaryRowSetting CartonsSummary1 = new SummaryRowSetting(WebDataGrid1, "Department");
CartonsSummary1.ShowSummaryButton = false;
this.WebDataGrid1.Behaviors.SummaryRow.ColumnSettings.Add(CartonsSummary1);
public void GetData()
DataTable tblShipment = new DataTable("Shipment");
tblShipment.Columns.Add(new DataColumn("NumOfCartons", typeof(int)));
UnboundField col = new UnboundField();
col.Key = "NumOfCartons";
col.Header.Text = "NumOfCartons";
this.WebDataGrid1.Columns.Add(col);
DataRow r = tblShipment.NewRow();
r["NumOfCartons"] = 30;
tblShipment.Rows.Add(r);
WebDataGrid1.DataSource = tblShipment;
//Bind the Dataset to the web grid
WebDataGrid1.DataBind();
The unbound field is not bound to anything its type should be specified explicitly. The default type is string and should be changed to numeric type by using the DataType property.
The updated version of GetData Method:
public void GetData(){ DataTable tblShipment = new DataTable("Shipment"); tblShipment.Columns.Add(new DataColumn("NumOfCartons", typeof(int))); UnboundField col = new UnboundField(); col.Key = "NumOfCartons"; col.Header.Text = "NumOfCartons"; col.DataType = "System.Int32"; this.WebDataGrid1.Columns.Add(col); DataRow r = tblShipment.NewRow(); r["NumOfCartons"] = 30; tblShipment.Rows.Add(r); WebDataGrid1.DataSource = tblShipment; //Bind the Dataset to the web grid WebDataGrid1.DataBind();}
Let me know if you need further assistance on this.
Thanks for the update.
I have a templated column with lnk button and I am trying to get the summary for the templated column. How do change the DataType for templated column?.
Please see the sample code as listed below.
public void GetData(){ DataTable tblShipment = new DataTable("Shipment"); tblShipment.Columns.Add(new DataColumn("DDC", typeof(int))); TemplateDataField tc = WebDataGrid1.Columns["DDC"] as TemplateDataField; if (tc == null) { tc = new TemplateDataField(); tc.Key = "DDC"; tc.Header.Text = "Expected In Store"; tc.ItemTemplate = new PlaceHolderTemplate(); tc.Width = Unit.Pixel(60); this.WebDataGrid1.Columns.Add(tc); } DataRow r = tblShipment.NewRow(); r["DDC"] = 30; tblShipment.Rows.Add(r); WebDataGrid1.DataSource = tblShipment; //Bind the Dataset to the web grid WebDataGrid1.DataBind();}
private class PlaceHolderTemplate : ITemplate {
#region ITemplate Members
public void InstantiateIn(Control container) { GridRecordItem gri = (GridRecordItem)((Infragistics.Web.UI.TemplateContainer)(container)).Item;
switch (gri.Column.Key) { case "DDC": LinkButton lnk = new LinkButton(); lnk.ID = "LinkButton1"; lnk.Attributes.Add("onClick", "ClientClick();"); container.Controls.Add(lnk); break; } } } protected void WebDataGrid1_InitializeRow(object sender, Infragistics.Web.UI.GridControls.RowEventArgs e) { LinkButton lnk; lnk = (LinkButton)e.Row.Items.FindItemByKey("DDC").FindControl("LinkButton1"); if (lnk != null) { lnk.Text = tblShipment.Rows[e.Row.Index][0].ToString(); lnk.Attributes["onclick"] = "BLOCKED SCRIPTbuttonClick('" + lnk.Text + "');"; lnk.Attributes["onmouseover"] = "this.style.color=\'#ff0000\'"; lnk.Attributes["onmouseout"] = "this.style.color=\'#000000\'"; lnk.ForeColor = Color.Black; lnk.Click += new EventHandler(this.lnk_Click);
The TemplateDataField has property Type.
Let me know if I may be of further assistance.
I tried to use type property, but not successful. Please send me the sample code demonstrating type property with TemplateDataField.
