3550
Automatically adjust row height to text on card view
I want to use card view.
I want row height to adjust automatically to text.
How can this be done?
This is my code but row height does not adjust. but stay fixed.
I use v8.1 with .net2
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Text;
using System.Windows.Forms;
using Infragistics.Win;
namespace WindowsApplication2
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        private void button1_Click(object sender, EventArgs e)
            List<Person> ls = new List<Person>();
            ls.Add(new Person("x""y" + Environment.NewLine + "z"));
            ls.Add(new Person("1""2"));
            ultraGrid1.DataSource = ls;
            ultraGrid1.DisplayLayout.Bands[0].Columns["Value"].PerformAutoResize();
        private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e)
            e.Layout.Bands[0].CardView = true;
            e.Layout.Bands[0].Columns["Value"].CellMultiLine = DefaultableBoolean.True;
            //e.Layout.Bands[0].Columns["DESCRIPTION"].CellMultiLine = DefaultableBoolean.True;
            e.Layout.Override.RowSizing = Infragistics.Win.UltraWinGrid.RowSizing.AutoFree;
            e.Layout.Bands[0].CardSettings.AutoFit = true;
    public class Person {
        private string mName;
        private string mValue;
        public Person(string name, string value)
            Name = name;
            Value = value;
        public string Name
            get { return mName; }
            set { mName = value; }
        public string Value
            get { return mValue; }
            set { mValue = value; }
Parents
No Data
Reply
  • 1980
    Hello drpoalim,
    You can size the cell heights of the grid by setting the UseRowLayout (RowLayoutStyle in newer versions) on the band and then the PrefferedCellSize property to a new size so that the cells’ text will fit in.
    private void ultraGrid1_InitializeLayout(object sender, InitializeLayoutEventArgs e)
                UltraGridLayout layout = e.Layout;
                UltraGridBand rootBand = layout.Bands[0];
                rootBand.CardView = true;
                //older versions
                rootBand.UseRowLayout = true;
                rootBand.Columns["Value"].RowLayoutColumnInfo.PreferredCellSize = new System.Drawing.Size(100, 40);
Children
