I am currently using Test Advantage 2011 V2 along with HP UFT 14 (latest version). I observe that the scripts recorded earlier which worked fine are no longer working now. The Swf objects are not getting recognized during playback and when trying to record, the steps involving the Swf objects are not getting recorded. Please help.
Below is the error message I get when I try to play back the scripts I recorded earlier, which were working absolutely fine till this morning:
Could not load file or assembly 'Infragistics2.Win.v11.2, Version=11.2.20112.9000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified.
Function file: C:\Users\pvemuri\Documents\Unified Functional Testing\OLF_QTP_Trade.qflLine (3): "SwfWindow("TradeExplorer").SwfWindow("Olf.Desktop.Controls.DesktopPl").SwfObject("explorerBar").SelectItem "Trading","New Instrument"".
Thanks.
Hello David,
I'm currently looking into your question. I will get back to you as soon as I have an update.
Thank you,Mihoko Kamiishi
It turned out that this is a known issue of Test Advantage.
Although TestAdvantage refers to build 9000 in the error message, QTP knows to automatically look for the closest build on the machine. This error means it could not find any build matching the major and minor version numbers.To debug this error, you can use ProcessExplorer to verify that the DLLs are not being loaded. If they are not there, please try putting the NetAdvantage assemblies into the GAC or QTP’s bin directory.
Also, please note that HP UFT 14 is supported only for Test Advantage v17.1 or later. If you use HP UFT 14 with Test Advantage v11.2, it may lead to any unexpected results.
Supported Environmentshttps://www.infragistics.com/support/supported-environments
