I have a grid that is re purposed for different types of data. I saw an example of enabling "features" in non-angular implementation to enable sorting/filtering globally on grid.
But when I try to enable "features" like below
<igx-grid #grid1 id="grid1" [data]="rowData" [autoGenerate]="true"> <features> <feature name="Sorting"> </feature> </features> </igx-grid>I get error - Uncaught Error: Template parse errors:'feature' is not a known element:1. If 'feature' is an Angular component, then verify that it is part of this module.2. To allow any element add 'NO_ERRORS_SCHEMA' to the '@NgModule.schemas' of this component. (" <igx-grid #grid1 id="grid1" [data]="rowData" [autoGenerate]="true"> <features> [ERROR ->]<feature name="Sorting"> </feature> </features>"): ng:///AppModule/AddnewComponent.html@123:8
Hello Pranay,
In the igx-grid sorting could be achieved with the following lines of code:
<igx-column field="ProductName" header="Product Name" [dataType]="'string'" sortable="true"></igx-column>
Filtering could be achieved with these lines:
<igx-grid #grid1 [data]="data" [autoGenerate]="false" [allowFiltering]="true">
More information about sorting and filtering could be found in our documentation: Grid Sorting Overview and Grid Filtering Overview.
You can also have filtering and sorting that can be turned on using buttons. There is a sample, which is described in the Data Grid Overview and Configuration in State persistence topic.
Monika Kirkova,
Thanks Monika,
This does solve the filtering and sorting. But I don't see any examples of show the grouping header where columns can be dragged/dropped. Can you please provide some sample code for that as well?
Grouping by header could be achieved with the following lines of code:
public ngOnInit() { grid.groupingExpressions = [
{ fieldName: 'ProductName', dir: SortingDirection.Desc },
{ fieldName: 'Released', dir: SortingDirection.Desc } ]; }
Columns can be dragged and dropped like this:
<igx-column [field]="'Category'" [movable]="true"></igx-column>
More information can be found in the Grid Group By section and the Grid Column Moving Overview section.
I have made a sample demonstrating grouping of rows and drag and drop of columns.
