I cannot scroll the grid by touch when using JsRender Integration.
I tested with a Micosoft Surface 2.
You can use the JsRender Integration demo to reproduce the issue.
Best regards,
Joern
Hello Joern,
About the issue with the vertical scrollbar. In Firefox currently there is a problem with the touch support, thus the touch events are disabled only on desktop version of the browser. For more information refer to this page: https://developer.mozilla.org/en-US/docs/Web/Guide/Events/Touch_events#Browser_compatibility. That's why you cannot scroll the grid.
how is the last comment related to this issue?
The problem that I reported is with IE11 / Windows 8.1.
Hi Joern,
As I understood from you first post, there is an issue with the scrollbar when using jsRender integration, and you have specified that we can find the issue in our web site, more exactly at (http://igniteui.com/grid/jsrender-integration). And that is happening under Microsoft Surface 2. I have tested it and truly the issue persisted, although it was only under Firefox browser. So my previous reply is regarding this particular issue.
Hello Zdravko,
could it be that you are talking about the "Surface 2 Pro"?
I just checked with a Surface 2 (RT) and I can still reproduce the problem at the URL that you mentioned.
Neither does touch scrolling work in the Metro UI Explorer, nor in IE on the desktop.
As I have said to you in Firefox currently there is a problem with the touch support. If you use approach similar to the sample, my suggestion is to use the workaround from my first post. Also I have tested the online sample and my own sample that I have created for you with Metro UI Explorer and IE, and the vertical scrollbar displayed correctly.
Could you please tell me is this issue appearing in your project, and if so, could you please try the suggestion from my first post.
I believe there is another missunderstanding.
Yes, scrolling works and, yes, the scrollbar is visible.
But on my Surface 2 in IE touch scrolling is not working. (Kinetic scrolling)
Usually I can swipe the igGrid with a finger to scroll. With jsRender integration it did not work.
Today, I tried again and now touch scrolling is not working at all in any of the Ignite UI samples on a Surface 2 with IE. When swiping a finger over the grid, there is only selection bar that moves up and down, but no scrolling. Has there been a change in a recent service release?
On an Android tablet that I tested it is working.
I just have tested touch scrolling with IE app version 10.0.9200.16540 and it works well. Could you please tell me what is your version of IE in order to perform correct check. Also about your question, you are asking about some change regarding igGrid JS rendering or touch scrolling?
Microsoft Surface 2 has Windows 8.1 with Internet Explorer 11.
I do not ask about any changes.
I am reporting a bug: Touch scrolling (aka "kinetic scrolling", "scrolling by swiping the table") does not work.
(First, I noticed it with the JsRender integration sample, but now none of the samples work correctly.)
I just checked another tablet (Intel based) with Windows 8.1 and Internet Explorer 11 - same problem!
In which Ignite UI build you're experiencing the problem? We fixed a similar issue in our latest SR: 13.2.20132.2157.
Best regards,Martin PavlovInfragistics, Inc.
Hello Martin,
in the Ignite UI online demos. So whatever version is online at www.igniteui.com,
(Maybe, the SR caused the additional problem. As noted before, first I saw the problem with JsRender integration, now touch scrolling with IE11 does not work with any of the online demos.)
We didn't do service release on the igniteui.com so there is an older version of the Ignite UI product 13.2.20132.2055. That's why you see the problem there. We will update it for the 14.1 release later this month.
Hope this helps,Martin PavlovInfragistics, Inc.
