40
how to fix WebUpload problem
I am trying to upload files in WebUpload 2012.1 version.
i added some references,<script type="text/javascript" src="~/ig_ui/js/infragistics.js"></script> , etc.
But it is not working and i have Message that is "The Infragistics WebUpload requires its own script to be loaded."
I didin't find answer in this Forums. Can you please tell me how do i FIX ?
I appreciate if you have answer.
<%@ Page Language="C#" AutoEventWireup="true" CodeFile="up1.aspx.cs" Inherits="up1" %>
<%@ Register assembly="Infragistics4.Web.jQuery.v12.1, Version=12.1.20121.2236, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.Web.UI.EditorControls" tagprefix="ig" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
    <title></title>
  <link type="text/css" href="~/ig_ui/css/themes/infragistics/infragistics.theme.css" rel="stylesheet" />
  <link type="text/css" href="~/ig_ui/css/structure/infragistics.css" rel="stylesheet" />
  <script type="text/javascript" src="http://code.jquery.com/jquery-1.4.4.js"></script>
    <script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jqueryui/1.8.16/jquery-ui.js"></script>
    <script type="text/javascript" language="javascript">
     $(function () {
      $("#upload").igUpload({
       mode: "single",
       autostartupload: true,
       // to upload a file, you need a server-side handler
       progressUrl: "IGUploadStatusHandler.ashx",
       controlId: "serverID"
    </script>
     function onErrorHandler(e, args) {
      var message = "ErrorCode" + ": " + args.errorCode + "<br />" +
              "ErrorMessage" + ": " + args.errorMessage + "<br />" +
               "ErrorType " + ": " + args.errorType + "<br />" +
                "ServerMessage" + ": " + args.serverMessage;
      alert(message);
   </script>
</head>
<body>
    <form id="form1" runat="server">
  <div id="upload">
       <ig:WebUpload ID="WebUpload1" runat="server"  Mode="Single" AutoStartUpload="true">
    <ClientEvents OnError="onErrorHandler" />
   </ig:WebUpload>
    </div>
    </form>
</body>
</html>
webupload.zip
Parents
  • 17590
    Verified Answer
    Hello Lee MH,
    What I noticed from the sample project provided is that you are trying to reference a script that is not actually present in the directory from the path used to reference it. This is the jQuery.tmpl.js file .
    Additionally, I noticed that the path used for referencing Infragistics.js script where all necessary scripts for the igUpload are located, is not correct. This means that script for the Uploader are not loaded ant this is the reason for the exception thrown in your browser. What I can suggest is using the following path for the Infragistics.js script:
    <%--<script type="text/javascript" src="~/ig_ui/js/jquery.tmpl.js"></script> --%>
    <script type="text/javascript" src="ig_ui/js/infragistics.js"></script>
    <%--<script type="text/javascript" src="~/ig_ui/js/infragistics.js"></script>--%>
    I hope this helps you resolve your issue.
    Please let me know if you need any further assistance with this matter.
Reply Children
