Hi, I just know how to disappear the specific area on xamWebChart. i have been searching it for long time, but i could not find it.
so i uploaded my programming's chart. i need your help...
Thank you for your post. I have been looking into the functionality that you are trying to achieve and I can suggest using XamDataChart and its UnknownValuePlotting property, since the XamWebChart is already retired and the XamDataChart provides more accurate control over the drawn data and also better performance (you can read more detailed information regarding the control retirements here: http://www.infragistics.com/community/blogs/jason_beres/archive/2011/01/01/important-product-changes-and-control-retirements-in-2011-2.aspx). You can make your data nullable and by setting the UnknownValuePlotting to null the data points that has null values will not be drown onto the XamDataChart and gaps will appear. You can read more detailed information regarding XamDataChart here: http://help.infragistics.com/NetAdvantage/WPF/urrent/CLR4.0/?page=xamDataChart_Getting_Started_with_xamDataChart.html and for the UnknownValuePlotting property here: http://help.infragistics.com/NetAdvantage/WPF/urrent/CLR4.0/?page=InfragisticsWPF4.DataVisualization.v12.2~Infragistics.Controls.Charts.UnknownValuePlotting.html. I have also created a sample application for you, that shows how you can implement this functionality using XamDataChart.
Please let me know if you need any further assistance on the matter.
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
