Hi guys and Girls,
We are having issues getting to our SharePoint 2013 sites, even though we can get to our 2010 sites fine. They are all under the same SSL certificate.
Our original issue was;
"AUTHENTICATION FAILS A connection failure occured: SSL problem (Possible causes may include a bad/expired/self-signed certificate, clock set to wrong date)"
Following the below link forum suggestion, I changed the network stack in the advanced settings;
http://www.infragistics.com/community/forums/t/97959.aspx
Issue now is that it constantly asked for authentication, even though i am putting them in correctly?
Playing with the SSL Level I set this as TLS v1 (as for security we do not support SSL v1, v2 or v3 as they are quite vulnerable so instead use TLS) and the constant request for credentials kept occuring.
This has been resolved by changing the Authentication mode to Web Login.
Hello Daniel,
We're glad to hear the issue has been solved, do you have further questions?Should we keep this case open?
Regards
Gonzalo T Associate Support Specialist Enterprise Mobility Infragistics, Inc.
If you're looking for a woman from another country for marriage, online dating can be the perfect solution. A marriage agency matches up family-oriented men with beautiful women from all over the world. Mail order brides go through an evaluation process before they can be put on a dating website. The process can be complicated, but it's well worth the effort. It can also lead to a beautiful marriage. However, online dating does come with certain pitfalls. Here are some of the most common ones.
I am getting more and more furious with this nyt sudoku issue. I tried many ways but they didn't work.
