Hi All,
I can not see all list of users from our SharePoint portal with Shareplus Pro. What could be the reason for this?
@ geometry dash lite Hello,
If your SharePoint portal has a large number of users, the app might have limitations on the number of users it can display at once. In such cases, the app may show a limited subset of users or provide pagination options to navigate through the complete list.
Hello Kursat,
I'm writing to you in order to check if you have further questions.
I will keep this case open for another three days while I wait for your response. If at that time you haven't responded, I will close this case as inactive. Please note that closed cases may be reopened within thirty days of closure.
Best regards.
Gonzalo T Associate Support Specialist Enterprise Mobility Infragistics, Inc.
Are you referring to the Social Hub in the navigation bar?If so, please try tapping over it, then tap on "People" at the bottom of the screen.Once there you should be able to see a selector to see people you are following and your Followers.
Please let us know if you have further questions.
Regards
Gonzalo TAssociate Support SpecialistEnterprise MobilityInfragistics, Inc.
