Does the app have the functionally to have create new item from favorites. Example i have a list on my Sharepoint that is a task list that i use heavily. i have the list added as a favorites, but in order to add items to this list i have to press on the list name, press on the +, and then press on the create type. Is it possible to have a favorite that gets me straight to the create type as favorite ? If not, this feature would be very helpful for all users.
Hello Tommy,
I'm afraid that SharePlus Pro doesn't support a favorite direct to adding a new item.It is possible although in an Enterprise build, through the use of a Launchpad as home.
I would recommend you to add the list as a favorite if you haven't already done so, once you have the quick access there, you can just tap the plus (+) button in order to add a new item to it.You can also add this idea in http://mobility-ideas.infragistics.com/ The ideas with the most votes will be taken into consideration sooner by our developers in order to anaylze if adding the functionality is possible.
Please let us know if you have further questions, regards.
Gonzalo TAssociate Support SpecialistEnterprise MobilityInfragistics, Inc.
I'm writing to you in order to check if you have further questions.
I will keep this case open for another three days while I wait for your response. If at that time you haven't responded, I will close this case as inactive. Please note that closed cases may be reopened within thirty days of closure.
Best regards.
Gonzalo T Associate Support Specialist Enterprise Mobility Infragistics, Inc.
I may use "add document" to add forms to the browser. I'm not manually adding XML files to a document repository. | security fencing wellington
