Hallo,
I bought Shareplus today, because I thougt it was the most effective tool to work with my mobile and SharePoint.
Unfortunately I did not test the ability of showing and creating attachments. I was sure, that Shareplus is able to deal with, because all the other competitors like harmon.ie, filamente and even SPConnect were able to handle attachments.
Now I read, that the attachment issue is discussed for such a long time ....
Can you give me any information about the actual state of affairs ?
Thank you
Petra
Hello Petra,
Thank you for contacting Infragistics!In order to get some context information on the issue, I would like to have a look at the app's technical logs.Please click here and follow the steps in that forum post in order to enable and send us SharePlus' technical logs after reproducing the issue a couple of times.
You can forward the compressed log folder to support@infragistics.com including this case number in the subject.Regards
Gonzalo Totorica Associate Support Specialist +1 (609) 448 2000 ext 1277 Enterprise Mobility | Infragistics, Inc.
Hello Gonzalo,
I do not understand why I should send you the log files ????
My problem is not a thing I can reproduduce. There is a missing funktion – simply said.
I use the android version of shareplus. There is no possibility to create an attachment like a photo or any other document to a list entry.
I do not even see an attachment, which was attached before.
In other apps like SPConnect or harmon.ie I can make a photo and attach to a list entry.
When I work with the iOS-App I can see the attachments.
I had mistakenly understood that you were having an issue with SharePlus.Bare in mind that if you're using the Lite version, you will only be able to see the first 10 entries on any list, subsite, folder, or library.The free version is only a preview version of the app.In order to use the full range of features of SharePlus you will need to purchase it for Android as Pro purchases are not Cross-Platform.
If you're having issues uploading items and, or attachments using the Pro version of SharePlus, please let me know.
Regards
I wrote that I BOUGHT Shareplus. I paid for it. I do NOT use the Lite version. I use the Pro Version.
I can't see attachments in Shareplus and I can't upload any document.
I apologize for the misunderstaning.Adding attachments or seeing the attachments from a list entry is not supported for the time being.You can add votes to this idea in the following link: http://mobility-ideas.infragistics.com/forums/286545-shareplus/category/96927-android-pro-app-store?query=attachmentsThe ideas with the most votes will be considered to addition to the developers' roadmap will be taken into study for implementation sooner.Please let me know if you have further questions.Regards
