I've tryed to connect multiple android devices to our sharepoint site but it generates the following error:
"SharePlus can't validate your server's certificate to ensure a secure channel. Please contact your IT Helpdesk for assistance."
We also connected IOS devices and they work just fine.
On both android and ios we are running the pro version of Shareplus.
Last year the same site worked just fine on andriod.
Wat could me a solution?
Kind regard,
Maarten de Kruijf
Hello Maarten,
Thank you for contacting Infragistics!In order to get some context information on the error, I would like to know which versions of both, SharePlus and Android OS are you using.Looking forward to your reply.Regards
Gonzalo Totorica Associate Support Specialist +1 (609) 448 2000 ext 1277 Enterprise Mobility | Infragistics, Inc.
Hi Gonzalo,
I'm not sure about the IOS device (as it is in a different location at the moment), but the android device runs version 2.0.528. The ios devices have been updated so they should be running the latest version from the appstore.
We would like to send you a test build which has a fix for the issue.I will go ahead and create a new support case for you and provide the build that way.Let me know if you have further questions.Regards
I've done a little more testing with different types of pdfs. This forum will not allow me to upload pdf's, so please let me know where to send examples and I gladly will. concrete driveway contractor
Lors de l'utilisation de systèmes d'exploitation, nous pouvons voir que chaque système d'exploitation présente des avantages et des inconvénients différents. Il y a des avantages que seul iOS peut faire.
stickman fighter
