Hi, I'm new to SharePlus and trying SharePlus for Airwatch on an iPad.
I noticed that my calculated field shows NaN instead of the expected link.
We use this as the calculated field: =TEKST.SAMENVOEGEN("<DIV><a href='";" <sharepoint url>?FilterField1=Productcode&FilterValue1=";Productcode;"'>Details</a></DIV>")
It works fine on our on prem SP 2013 as lon as we tell SharePoint it is a number (instead of a text string). If we tell SP it is text, it does not translate the url to a clickable link.
Is this because we have a trial version of is SharePlus not able to use the calculated field this way?
TEKST.SAMENVOEGEN is Dutch for CONCATENATE
The most likely cause of this is an incompatibility. If the text field is defined as plain text, it is likely that SharePlus will read the value as a text string rather than a hyperlink. | retaining timber
Reading advancedwriters reviews is a smart surviv io idea before making an order on the company's website. How to use the service was covered in great detail in this review.
more votes equals more weight the greater the possibility that your suggestion will be included in a future release of the app.
geometry dash
There are many trial versions that are really worth thinking about. But I don't like using the trial version.
iscribble
Gert,
I think you'll need to help me build a test environment on my end, unless you can provide me with access to it. If only the former is possible please describe:
It may help if you crafted a spreadsheet as an example so I can duplicate the list on my end.
Thanks in advance,
