Hi
Are there example Workspaces for SharePlus?
I would like to have a starting point for creating my own to see how the deployment work
Hi Glenn!
Workspaces in SharePlus work in a number of ways, from a fully custom web page, to a
Check please our help page where the details:
https://www.infragistics.com/help/shareplus/enterprise-shareplus-mobile-workspaces
I can also add your email to a Demo we have with a few sites and a pre-configured Workspace for you to navigate and test it.
Also, feel free to play around with our Workspace generator which can be found here:
http://emm.infragistics.com/mobileworkspaces/generator.html#/
Once you create it, download the workspace and place the WorkspaceName.web.zip anywhere in your SharePoint. You can navigate to it within SharePlus and establish it as the app’s Home by tapping-holding on to it, then “Add as Home”.
Let me know how you want to proceed so I can set you up properly.
Kind regards,
Adrián PévereSenior Support Specialist.
Thanks - Generator works!
Having some issue getting content to display
ie SharePoint list for link
https://mydomain.sharepoint.com/enet/JobPacks/Lists/Job%20Pack%20%20Stations/AllItems.aspx
The link work via the Generator test but not on the App
Get the error "List View not found"
Any ideas?
Hi Glenn,That is most likely related to trying to use the whole path. Remove please the AllItems.aspx part which should allow the workspace to reach the list. Also, in case you have more than one which is actually the purpose, try to add under Content in SharePlus an access to this same library. This will help SharePlus in establishing the connection to that location so as to list through the workspace as well.
All the best,
Adrián.
Can you export the path of a working one to use for configuration of the workspace? This would be very handy
You can check how another workspace is configured by extracting its content and looking for the Custom > config.js file where all of the paths are present.
Check it out!
