Can anyone send me a whitepaper or directions on setting up .p12 certificate authentication for this app. Trying to use certificate authentication to Sharepoint.
Mark
Mark,
Thank you for posting at Infragistics forums!
Setting up a .p12 certificate with SharePlus is possible and easy if you follow these guidelines:
Get your .p12 certificate into SharePlus' Local Files. This can be done by enabling WiFi sharing in Local Files and copying the certificate from your PC:
Then go to a web browser and add the .p12 certificate:
Now go to the site configuration dialog and enable User Certificate, the certificate you just added via WiFi Sharing will be available (remember the format must be p12; if it were in pfx just rename it to p12):
Input the password and tap Done.
You are now ready to connect to your site using a client side certificate.
Is there anything else I can help you with?
Javier
Relevant service reviews are exactly what college students need in order to prevent devastating cooperation that may impair academic prosperity. There is an unlimited number of alternatives worth time and attention. https://bestpaperwritingservicereviews.com/reviews/essaywriter-review
How are the actions to be taken lolbeans? Thanks.
