After using SharePlus Mobile (Pro) for a few months, we have a few more questions mostly about viewing PDFs within the app on an iPad:
Hi jlclark,
Thank you for posting at IG forums!
What version of SharePlus are you running? Is it 2.9.8? There were stability issues with the built-in PDF viewer in previous versions that were fixed in v2.9.8.
The upcoming verision (v3.0 in about a week) has an even more improved viewer, in terms of performance.
PDF annotation tools is definitely somethig that we could implement for you in an Enterprise level deployment.
I'll put you in contact with one of our sales representatives for you to discuss the details on SharePlus Enterprise.
Is there anything else I can assist you with?
Best regards,
Javier da Rosa Solutions Engineer, Infragistics Tel: 1 (609) 448 2000 x1352jdarosa@infragistics.com | www.infragistics.com
Yes, we are running 2.9.8. We look forward to an update to see if our issues are resolved.
Could the way the PDFs are formatted also be a problem? Do you have any recommendations for how the PDFs are generated?
Thanks for your help!
According to our developers our viewer supports PDF 1.7 and older versions.
The viewer does not support overlay, this means annotated PDFs need to be flattened for SharePlus to display annotations.
Besides this, I can't think of any other recomendations.
I have the latest version of SharePlus installed on my iPad 2 with iOS5.1
I can't seem to open PDF's into SharePlus. The Open In command does not show SharePlus as an option. I've tried this from GoodNotes, GoodReader, and Docs to Go. They open other formats fine but not the PDF.
Hi Joe,
I saw you email as well :)
Can you count how many apps do you see in the Open In menu? Are they 10?
Looking forward to hearing from you,
Javier da Rosa Solutions Engineer, InfragisticsTel: 1 (609) 448 2000 x1352jdarosa@infragistics.com | www.infragistics.com
