The links to lists and items in my favorites do not work: when tapping I get the following error:
Item not found
There is no subsite available that contains the selected content
Ignore Remove
Only links to items in the root of our website seem to work.
Is there a way to make this signature annotation secure and thereafter uneditable? | concrete driveway contractor
Hello seashore67,
Thank you for posting at IG forums!
I have created a case for you. You may go to Infragistics.com > Account > My Support activities and review the case CAS-95025-WBLF06.
As soon as we troubleshoot this issue we'll post a response in this thread.
Best regards,
Hi Javier,
I just tested this in the version 3.2 and it still does not appear to be working. Was this fixed?
Andrew
Indeed, this has been fixed and will be available in SharePlus v3.2 coming out next week.
I attempted to do what you speak of and still received the same error. I'm only using the 30 day demo, but you say this should be fixed in the new release. Is this still planned to be fixed?
