In opening a PDF file (which requires a password to open):
1- I was prompted for a 'document password' and entered the proper password,
2- A message appeared stating "Error opening document, The document has no pages" and I click OK,
3- from the blank screen, I click on the EDIT button and I am able to open the document via the Adobe Reader app (after entering the password again in Adobe Reader).
Is this the expected functionality within SharePlus Pro?? I was hoping to open the password-protected file from within SharePlus but it appears I cannot???
Please advise. thanks.
-Steve
An easy process to figure out how to open a protected PDF password is to use the pcinfotools PDF Unlocker program. This option allows you to quickly and easily remove the password protection of one or more PDF files. If Adobe Reader is not currently installed on your computer, you can quickly remove passwords and limitations on editing, copying, and printing PDF documents. It works with Windows 8, 7, 10, 11, and previous versions.
There are several solutions to unlock PDF files to meet your needs. However, the search supports the professional process used by the OSTtoPSTAPP PDF Unlock Software. Its easy-to-use interface speeds up the blending process. All Windows versions, including 11, 10, 8.1, 8, 7, Vista, XP, and earlier ones, are fully compatible with the application.
Read More:- www.osttopstapp.com/pdf-unlocker.html
If you have forgotten your PDF password, then you use SysTools PDF Unlocker Tool which can unlock your PDF files with ease. It not only removes password but also restriction on printing, copying, and editing pages and support bulk operations. It beneficial for security personal and it related domain people.
Read More:- www.systoolsgroup.com/pdf-unlocker.html
If you are facing similar issue like cannot open PDF file which requires password. Then, you can opt for BitRecover PDF Unlock Wizard where you can lock PDF from editing while sharing with anyone. Also, it prevents user from duplicating data with disable content copying option. Moreover, it is beneficial for government, defense, financial sector to secure PDF with password.
Read More:- www.bitrecover.com/.../
Hi, as a user I would like to suggest a professional Mac PDF Unlocker Tool that will help you to unlock or open PDF files by removing passwords from them. MacSonik PDF Unlocker for Mac is an advanced and dedicated utility I've ever used to remove passwords from my PDF files. It also enables editing the PDF metadata after unlocking. Users can remove passwords from single or multiple PDF files without losing any data. It has an option to customize the name and specific location of the resultant file.
