I just started using SharePlus Lite. I read the SharePlus PDF user manual, which has a tutorial showing how to set up offline support so that documents are cached and accessible when not connected to wifi. But the screenshots and buttons that appear in the tutorial do not appear in the actual app (version 3.18.6). Is that because I am using SharePlus Lite? Can download / syncing of documents from SharePoint down to an iPad be done with SharePlus Lite? Or is downloading / syncing of documents only available in SharePlus Pro? Thx
Hi Tom,
Thank you for posting at IG forums!
SharePlus LITE does not have offline support. In oder to being able to sync your lists for offline access you need to have SharePlus PRO.
Is there anything else I can do for you?
It may be a little late on your particular example, however I'm leaving here the answer in case it helps someone else.
concrete driveway contractor
