Running iOS 6 with SharePlus Pro v 3.8.2, connecting to a SharePoint Foundations 2010 site.
I have a survey that I'm hoping to have my users fill out on the go, however some of the answers are somehow pulling values from the survey and combining them to the questions answer.
I have attached a screen shot to show everyone what is happening. Does anyone have an idea how I can fix this? In this particular example, the field is a radio button list. As you can see, the number 18 has been added, as well as another value (that I blurred out). These values are values, but from other parts of the survey. 18 is the id number I believe.
Hello David,
Thank you for posting at IG forums!
Would you mind provide me the field’s definition/configuration from SharePoint?
Looking forward to hearing from you,
Hello!
The field's are lookup's which pull values from another list.
Any idea why this is happening?
Thanks!
David,
Thank you for the extra info.
We need to know more about that field and the field that it pulls data from.
It looks like it could be a calculated field that's concatenating the values from several other columns.
What authentication mode does your site use? What version of SharePoint are you connecting to? Concrete Driveways
