We run SharePoint 2007 which is published via TMG using public certificates.
For some reason on the Iphone/Ipad version of the App I am able to connect to SharePoint and browse the sites however if I try and open up any document it just sits there.
I've setup a log on TMG and found that SharePlus is attempting to use port 80 only when opening documents? Not port 443.
Port 80 is of course blocked.
In the android version of the app everything works as normal.
Any ideas?
Hello Nathan,
Thank you for posting at IG forums!
Please try adding the port in the URL “:443”
I'll be looking forward to hearing from you,
You can try opening the PDF in a 3rd party app like PDF Expert, Adobe Reader or any other PDF tool. Then, once flattened, you can save it back to SharePlus. | Roof Leaks
