When I browse to a list in SharePlus I see a quick view of all list entries with limited data displayed as shown in the attached Screenshot1. How do I control which field is displayed in this quick view - or add additional fields to this quick view? Screenshot2 shows the item properties. Let's say that I wanted the "Cost or Value" field to show up in the quick view instead of the "Entry Type" field? Let's say that I wanted both the "Cost or Value" and the "Entry Type" fields to show up - is that also possible?
Here's Screenshot2.
Hello Micah,
I have been looking into your posts. It seems that the columns to be displayed are selected based on the view in each SharePoint view. It means that the columns are displayed in a particular order
in the iPhone. Their count depends on the size limitations. You need to change manually the order of the columns to have "Cost or Value" as column 1, "Entry type" as columns 2 and so on. For more information please look into the following link :
http://mscerts.programming4.us/sharepoint/sharepoint%202010%20%20%20change%20the%20order%20of%20columns%20in%20a%20list%20or%20document%20library.aspx
Let me know, if you need any further assistance on this matter.
Thank you, I will test this out today.
I understand that the order of info displayed in SharePlus is related to the order of the columns. However, did you also say that the number of columns shown in the Quick View is relative to the size of the screen that's being used to run SharePlus? For instance, a larger screen would automatically show details of additional columns in the Quick View?
Hi Micah,
Thank you for your feedback. I have been looking into your question and I have tested the view on iPad and only two columns appears for each file, too.
Sorry for the misunderstanding.
Is there any way to make more than 2 columns appear in this SharePlus quick view?
