Can I use SSL Certificates in Lite version? I add p12-certificate in iTunes, but SharePlus don`t find it. I can`t load certificates from WiFi because Lite version don`t support it.
Andrew,
Thank you for posting at IG forums!
There is a workaround for this.
SharePlus needs the certificate in Local Files. You may access them by syncing your iPad with iTunes then going to Applications > File Sharing and clicking in SharePlus Lite. You may add your certificate there.
Please try this and let me know should you need further help.
Thank you.
I have just done it many times, but when i opened application, the certificate was absent. And when I opened iTunes again, the certificate was absand in iTunes too. I think that Lite version delete any file from Local Files, when It open.
Javier,
Do you have any idea?
