I'm currently evaluating SharePlus for usage with our elderly Sharepoint 2010 installation. Most of the software I find both pleasant and well thought out, but logging on to our server is problematic, as authentication is handled by an ISA server (Forefront Threat Management Gateway), which is not directly supported by SharePlus. My problem is that the web login route is pretty inconvenient in SharePlus, as no login credentials are remembered or at least pre-filled, wich means typing all credentials whenever a refresh is needed, or SharePlus is purged from memory by iOS (oh, and did I mention the web login window disappears when you switch to another app to retrieve the password?). As it is, this is pretty much a no-go, so I would like to know if improvements on this front are to be expected soon(-ish)? Not necessarily native ISA authentication support, though that would be nice of course, but something like pre-filling credentials stored in the iOS keychain in the web login form (personally, I’d even make do with 1Password extension support, but that won’t scale to other users ;)).
wow, such an old post!
d4 gold
I'm looking for a higher version of SharePoint. Can you share them with me?
lolbeans
The delete button will be changed to a + icon. Tap this and Browse to select the new document that will replace the original. emergency plumbing
Martin,
That's even better!
Thank you for certifying the answer.
Please let us know if you have other questions.
Regards
Gonzalo T Technical Support Engineer I Enterprise Mobility Infragistics, Inc.
Hi Gonzalo,
thanks or or the quick response! As it turns out, setting the SharePlus user agent to “SharePlus” is enough – SharePoint 2010 default configuration is to fall back to basic authentication for unknown user agents (as documented in your first link), solving the issue. Good to know.
