445
clear filter result in webdropdown
I have 10 records bound to a webdropdown for which I have enabled the EnableAutoFiltering="Client" and the filtering is working fine. When a user searches for a an item which is not available in the dropdown list, it shows empty (0 records and dropdown container becomes empty). Now when the user leaves the dropdown, I would like to reset the dropdown items to its original (10 items).
How can I reset the filtered result of a webdropdown?
Parents
  • 7375
    Hello Nagraj,
    Thank you for posting in our forums!
    I have done some research on this and found that in the webdropdown you are using property EnableAutoFiltering="Client".
    When you set Auto Filtering client side the filtering is performed only on the client-side items collection contents,
    with no postbacks taking place. To reset the Dropdown you can use public method clearFilter , it clears the applied filter programmatically.
    function clearFilter()
    var resultVar = instanceOfWebDropDown.clearFilter();
    You can refer the following API link:
    http://help.infragistics.com/doc/ASPNET/2015.2/CLR4.0/?page=WebDropDown~Infragistics.Web.UI.WebDropDown~clearFilter.html
    Please let me know if I may be of further assistance.
Reply Children
