40
infragistics webdatagrid checkbox partial
I am using infragistics web datagrid. I have set auto generate columns to false. And adding 20 blank rows to the grid from code behind. Then using javascript method to loop through all columns all rows to set the values of each column.
eg: grid.get_rows().get_row(i).get_cell(0).set_value(false);
There is one checkbox column on grid. If the value of the column is false; When the grid is loaded first time it displays blank checkbox. But when a postback occurs, the checkbox UI is changed to partial. (blue filled checkbox). When I do grid.get_rows().get_row(i).get_cell(0).get_value() it shows correctly, i.e. false. but not sure why it shows partial.
Parents
  • 11095
    Is the checkbox column unbound or bound? What is the grid configuration - markup and code behind? The best way for us to assist you is if you provide a small isolated sample that we can run and use for debugging locally.
Reply Children
